How do I create an 'L' shaped structure with automatic gable ends?
A reverse gable, sometimes called an opposing gable, is perpendicular to the main gable roof. A reverse gable can join the main roof anywhere along the main roof. In this example, it joins the main roof at one end.
To build a reverse gable roof
from the menu, then click and drag to draw the walls for your L-shaped structure in a clockwise fashion.
- Extend the baseline wall through the bump-out of the L.
- Select the wall with Select Objects
and then on the Edit toolbar, choose the Add Break
edit tool. Click to place a break in the wall where the baseline wall meets the gable.
- For each of the wall segments that need to be a gable, select the wall, then click the Open Object
tool on the Edit toolbar.
- On the Roof panel of the Wall Specification dialog that displays, select Full Gable Wall, then click OK.
- Pull the baseline wall's end back to its original location.
from the menu to open the Build Roof dialog.
If Auto Rebuild Roofs is enabled, this step, along with the next step (Step 8) are not necessary.
- Check the Build Roof Planes box, then click OK to build the roof.
from the menu to see the results.
