I need to model cabinets with frameless construction. How can I do this?
Frameless, or European style cabinets, are characterized by door and drawer fronts that cover most or all of the cabinet front, narrow gaps between front items, and hidden hinges.
You can easily set up your cabinets in Chief Architect to model this type of cabinet.
In many cases, it's best to design your cabinets in the Cabinet Defaults before you place any cabinets in your plan. You can, however, assign these specifications to any cabinet on an object by object basis in the Cabinet Specification dialog.
In this example, we will modify a single cabinet.
To create frameless cabinets
Select Build> Cabinet> Base Cabinet
from the menu, then click in the drawing area to place a base cabinet at that location.
tool, click on the base cabinet to select it and select the Open Object
edit button to display the Base Cabinet Specification dialog.
- On the General panel:
- Set the Countertop Thickness and Overhang, if necessary.
- If desired, Flat Sides and Flat Back for the toe kick can be set here.
- On the Box Construction panel:
- Under the Box Construction section, select Frameless.
- Under the Door/Drawer Overlay section, depending on your style preference, select Full Overlay and specify the desired Reveal value.
- On the Door/Drawer panel:
- Select the desired Door and Drawer Styles.
There are a selection of European style doors and drawers available in the Library Browser, or Slab Doors also work well for creating this style.
- Specify the desired Door and Drawer Handle styles.
A selection of styles are available in the Library Browser under Chief Architect Core Catalogs> Architectural> Hardware> Cabinet Hardware.
Depending on the handles you select, you may also want to adjust the In From Edge and Down from Top values.
- Specify Hidden for the Door Hinge Style.
