I am unable to download the Core Catalog files for Chief Architect Premier. How can I manually install them?
If you continuously encounter an error with downloading the Core Catalogs using the standard Library> Install Core Content method, then you may need to follow the steps below to download the catalog files to your computer, then copy them to their respective locations.
It's recommended to create a folder on your computer, in an easy to access location such as your desktop, where you can save these files to. If you do not do so, then they will download to the default file location your web browser is set to, which is typically your Downloads folder.
Click here to go to the Core Libraries and Referenced Files for X7 through X15.
Referenced Files are compressed .zip folders and need to be copied as-is; do not open or extract the contents of these files.
Open both the folder containing the downloaded files, as well as the destination location where the catalog files will be copied to, then copy or move the files from the download folder to the core catalog folder.
%programdata%
and press OK.
/Library/Application Support
and press Return.
X15
Download and save these Core Libraries for Chief Architect Premier X15
Download and save these Referenced Files for Chief Architect Premier X15:
X14
Download and save these Core Libraries for Chief Architect Premier X14:
Download and save these Referenced Files for Chief Architect Premier X14:
X13
Download and save these Core Libraries for Chief Architect Premier X13:
Download and save these Referenced Files for Chief Architect Premier X13:
X12
Download and save these Core Libraries for Chief Architect Premier X12:
Download and save these Referenced Files for Chief Architect Premier X12:
X11
Download and save these Core Libraries for Chief Architect Premier X11:
Download and save these Referenced Files for Chief Architect Premier X11:
X10
Download and save these Core Libraries for Chief Architect Premier X10:
Download and save these Referenced Files for Chief Architect Premier X10:
X9
Download and save these Core Libraries for Chief Architect Premier X9:
Download and save these Referenced Files for Chief Architect Premier X9:
X8
Download and save these Core Libraries for Chief Architect Premier X8:
Download and save these Referenced Files for Chief Architect Premier X8:
X7
Download and save these Core Libraries for Chief Architect Premier X7:
Download and save these Referenced Files for Chief Architect Premier X7:
