I want to change the direction of floor or ceiling joists in a certain area of my plan. How can this be done?
You can specify the direction that joists build using a Joist Direction Line, however this will force all the joists sharing a floor platform area (i.e., all floors or ceilings at the same elevation) to build in the direction specified. To change the direction joists build without changing the elevation of your floors or ceilings, place a Bearing Line along with multiple Joist Direction Lines to manually control the direction the joists generate.
In this example, a simple four-walled structure will be used. Notice that a basic foundation has already been created and floor joists have been generated for the first floor.
