I designed a floor plan, complete with fixtures, that must be duplicated on multiple levels of my project. What is the best way to do this?
In some situations, such as apartments, condominiums, or hotels, the floor plans on multiple floors will be nearly identical. While the Derive new floor plan from the 1st floor plan option will copy the layout of exterior walls, other objects like doors, windows, cabinets and fixtures, will not be duplicated.
It is possible, however, to duplicate all objects on a floor using the Edit Area tool.
To copy a floor plan to another level
- Create a new floor by selecting Build> Floor> Build New Floor
- In the New Floor dialog, select Make new blank plan for the 2nd floor, then click OK.
- In the Floor Defaults dialog that displays next, specify your desired floor and ceiling settings, then click OK to create a new blank floor level.
- Select Tools> Floor/Reference Display> Down One Floor
to move back down to Floor 1.
- Select Edit> Edit Area> Edit Area
, and draw an edit area polyline around the entire structure on this floor.
- Select Edit> Copy
- Select Tools> Floors/Reference Display> Up One Floor
to move up to the next floor.
- Select Edit> Paste> Paste Hold Position
to paste the copied area directly above the original.
Both floors should now look identical.
