Recently, I experienced a computer malfunction while working in the software and now when I try to open my plan file, an error message tells me that it cannot be opened by the program. What can I do to recover at least some of my work?
In the event that file corruption has occurred, and you're unable to successfully open one of your project files, you may be able to reference a backup copy located in the Archives.
C:\Users\ [YOUR USERNAME] \Documents\Chief Architect Premier X16 Data\Archives
/Users/ [YOUR USERNAME] /Documents/Chief Architect Premier X16 Data/Archives
Do not save this file in the Archives folder, nor in the programs Data folder.
Please see the "Organizing your Plan and Layout Files" resource in the Related Articles section below to learn more about the recommended practices for where to save your files.
If you have retrieved an archive file that contains views that have been sent to a layout*, some views may need to be re-linked. Please see the "Message: Could not successfully open all of this layout's associated plan files" resource in the Related Articles section below if you experience this message when opening the associated layout.
*Layouts are available in Chief Architect Premier, Chief Architect Interiors, and Home Designer Pro.
In Chief Architect Premier and Chief Architect Interiors, you can also specify how many Archives are created on the File Management panel of Preferences . However, it is important to note that these settings cannot guarantee full, exact restoration of your plan files under all circumstances.
