I need to create a Saltbox style roof, which is similar to an Offset Gable, in my plan. How can I create this?
A saltbox roof can be created automatically by generating an additional floor level and utilizing the Knee Wall setting located on the Roof panel of the Wall Specification dialog.
To create a saltbox roof
- In a blank plan, navigate to Build> Wall> Straight Exterior Wall
, then click and drag out 4 walls to create a basic 30' x 40' structure.
- Use the Select Objects
tool to click on the left 30' wall and select the Open Object
- On the Roof panel of the Wall Specification dialog that opens, select the Full Gable Wall option under the Roof Options section, then click OK.
Repeat Steps 2 and 3 to make the opposite wall a Full Gable Wall as well.
, and in the New Floor dialog that opens, choose to Derive new 2nd floor plan from the 1st floor plan, then click OK.
- On the newly created 2nd floor, Move
the top horizontal 40' wall inwards so that its distance from the bottom horizontal wall changes from 30' to 20'
- With this wall still selected, click the Open Object
- On the Roof panel of the Wall Specification dialog that opens, select the Knee Wall option under the Roof Options section, then click OK.
A knee wall's height is defined by the roof above, not the ceiling height.
- If Auto Rebuild Roofs is not enabled, navigate to Build> Roof> Build Roof
from the menu, check the Build Roof Planes box, then click OK to see the changes reflect in your plan.
