How do I create a manual dormer, such as a wall dormer in Chief Architect?
Many dormer types can be created automatically using the Auto Dormer tools. There are, however, some situations where dormers must be drawn manually. A wall dormer is a prime example.
To learn more about the Auto Dormer tools to create various types of roof dormers, please view the "Creating an Automatic Dormer" resource in the Related Articles section below.
To draw the dormer walls
the Chief Architect plan in which you want to build a manual wall dormer, or create a new plan by selecting File> New Plan
In this example, we will be using a 30' x 40' structure with a Cape Cod roof at a pitch of 8" in 12.
For information about creating a Cape Cod or a story and a half roof, see the Related Articles section below.
![30' x 40' structure](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig1-12.png?1696366394)
- In floor plan view, select Tools> Floor/Reference Display> Up One Floor
from the menu to go to the second floor.
![Second floor with roof planes displayed](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig2-12.png?1696366394)
If your roof planes are not displayed on the floor level the dormer will be created on, navigate to the floor level where they are currently displayed, select the roof plane(s), and click the Display on Floor Above
or Display on Floor Below
edit tool(s).
- Select Build> Wall> Exterior Wall
and draw two walls that will serve as the dormer's side walls, making sure that the exterior layer of each wall is facing outward.
![Dormer walls placed on the second floor](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig3b-12.png?1696366394)
- Adjust the position and length of each wall to your liking.
In this example, each dormer wall is 9' 6" in length and they are positioned approximately 11' apart.
![Dormer walls correctly positioned](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig4b-12.png?1696366394)
- Next, select one of the dormer walls, click the Open Object
edit button, and in the Wall Specification dialog that displays:
![Roof panel of the Wall Specification dialog](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig5-15.png?1696366394)
- Select the Roof panel and place a check in the Roof Cuts Wall at Bottom box.
- Click OK to close the dialog.
- Repeat step 5 on the opposite dormer wall.
To build the dormer's roof
tool, click on the existing roof plane that is currently above the dormer walls, then select the Add Break
Click to place break points where each wall meets the roof plane.
- With the breaks placed, adjust the roof plane so it no longer covers the dormer walls. The roof plane should be snapped to the outside of the wall's exterior layer - in this case, the siding layer.
![Adjust the roof plane so the dormer walls are no longer covered](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig7c-12.png?1696366394)
to verify that the dormer walls are exposed and are not covered by any roof planes.
![Perspective Full Overview showing the wall dormer](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig8b-12.png?1696366394)
- Select File> Close View to return to floor plan view, select the roof plane again, then place an additional break point along the back edge of the roof plane that was adjusted in step 3 above.
![Additional break point placed on the back edge of the adjusted roof plane](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig9c-12.png?1696366394)
- Drag the newly created break point towards the main ridge line to create a peak.
![Roof plane adjusted to create a peak](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig10b-12.png?1696366394)
- Next, select Build> Roof> Roof Plane
, and draw a small roof plane over each of the dormer side walls.
If the Set Baseline Height dialog appears, select Over Wall Top and click OK.
![Two roof planes drawn over each dormer wall](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig11b-12.png?1696366394)
- Join the two dormer roof planes at the ridge:
- Click on the ridge edge of either dormer roof plane to select that edge.
- Click the Join Roof Planes
- Click on the ridge edge of the other dormer roof plane.
![Join the two dormer roof planes at their ridge](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig12b-12.png?1696366394)
- Next, select the back edge of either dormer roof plane, click the Join Roof Planes
edit tool, then click the corresponding angled edge of the roof plane that was adjusted in step 6 above. The roof planes will now be parallel to each other. Perform this same procedure for the the opposite dormer roof plane.
![Joining dormer roof planes with the main roof](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig13b-12.gif?1696366394)
- Select 3D> Create Perspective View> Full Overview
to see the results.
![Perspective Full Overview of the structure with a wall dormer](https://d2haqc5836ials.cloudfront.net/live/KB-00449/449-fig14-12.png?1696366394)
You are now ready to add a window and other finishing touches.
