When I try to print my plan file, the Drawing Scale is set at 1/4" = 1'. I would like the scale to be something different. How do I change this?
If you have already sent a view to your layout file at a specific scale, and are printing from the layout, the Drawing Scale should remain at a 1:1 scale, and should not be changed.
When the Print View dialog is opened, the scale can be seen, but cannot be changed. To change the Drawing Scale in a plan file, access the Drawing Sheet Setup dialog.
To learn more about printing at a specific scale in Chief Architect, navigate to Help> Launch Help in your program, and search: Printing to Scale.
