Aligning Different Thickness Walls
Reference Number: KB-00798
Last Modified: July 19, 2021
I need to join walls that have different layer thicknesses and would like to control how these walls align to one another. How can I do this?
We can specify how walls align and then use Object Snaps to easily position them.
To set the snapping behavior
  1. Select Edit> Default Settings Default Settings tool icon from the menu.
  2. In the Default Settings dialog, expand the Walls category, click on General Wall to highlight it, then click the Edit button.
  3. In the General Wall Defaults dialog, the Resize About options determine how walls snap together.
The two walls illustrate how these options work. The wall on the left is a Siding-6 wall, the other is a Brick-6. The layers of the Brick-6 have been enlarged to better illustrate the differences in the Resize About options.
Two wall types unconnected
The walls shown have the framing selected as the main layer, the normal choice for walls.
  • Outer Surface
    Select this option to align the outer surfaces of walls when they snap together.
    The outside surface of the walls are aligned
  • Main Layer Outside
    This option aligns the outer surface of the main layer.
    The outside edge of the main layer of the walls are aligned
  • Wall Center
    If you choose this option, the program aligns the wall centers.
    The center of the walls are aligned
  • Main Layer Inside
    Select this option to align the inside surfaces of the main layer.
    The inside edge of the main layer of the walls are aligned
  • Inner Surface
    This options aligns the interior surfaces of the walls.
    The interior surface of the walls are aligned
