I am getting the following message about deleting a saved camera:
What does this mean?
If you have a saved camera in your plan, you can select and then edit or delete it. If the camera view is a cross section/elevation view that has been sent to layout and you choose to delete it, however, the link between the layout and plan will be broken. The view may remain visible on the layout page but it will no longer update as changes are made to the plan and any CAD objects you drew in the view will no longer be present.
There are several ways to respond to respond to this message:
If you always want the program to either delete or not delete a selected camera and never warn you again, you can check the Remember my choice during this session checkbox at the bottom left corner of the warning message and then click either the Yes or No button. If you select a camera and delete it after checking Remember my choice during this session, the program will either delete it or not delete it based on your answer and will no longer prompt you with this dialog during this session.
