How do I use the Extrude Object edit tool to turn a Face object into a 3D solid?
The Extrude Object edit tool can be useful for creating a solid object instantly from a 2-dimensional face object. Faces are two-sided, can display in 3D views, and can be used to create custom solid objects.
For the purposes of this example, we will start by drawing a face in the 2D floor plan view, however, faces can also be drawn in Cross Section/Elevation views. We will then extrude the face to create a basalt column.
If you have created another type of primitive, such as a Box or Pyramid, you can also choose the Explode Shape edit tool in order to convert its sides into individual faces, which can then be extruded to create a wide variety of different types of objects.
Often you can use these tools in combination with the Solid Union, Intersection, and Subtraction edit tools to create almost any type of custom shape desired. These shapes can then be converted into 3D symbols, such as fixtures or furnishings, for use in future plans. To learn more, see the Related Articles section below.
