When I edited the layers of one of my wall types, this message displayed:
What does this mean?
This message indicates that you have changed the Main Layers section for one of the wall types that exists in your current plan, and that walls will be moved to accommodate this change. Check to make sure this is what you really intended to do, and if not, follow the instructions below to restore the Main Layers.
Recall that in most circumstances, the Main Layers should include the structural layer of the wall, particularly when the wall is a framed type.
The Main Layers section determines many things, including:
All of this information is reliant on the Main Layers section, so creating your wall type definitions accurately before creating your floor plan and specifying the Main Layers is very important.
If you want to be able to adjust the Main Layer of your walls without having them move, you first need to adjust your General Wall Defaults prior to making modifications to the wall type.
*Applies to Chief Architect Premier, Chief Architect Interiors, and Home Designer Pro.
These radio buttons determine what part of a wall retains its position when its wall type or wall type definition is changed.
The Resize About setting is also where any snap points will be located along a wall as it is drawn or connected to other walls, and is where a wall's length is measured.
