Message: The material appears to have an incorrect pattern.
Reference Number: KB-01124
Last Modified: October 31, 2024
DESCRIPTION
When I open an old plan in the current program version, I sometimes see a message stating:
  • "#272032209 - The material "X" appears to have an incorrect pattern. The pattern has been reset to default."
What does this mean?
RESOLUTION
Materials are represented by patterns in 3D views using a variety of rendering techniques, including Vector View, Technical Illustration, and Hand Drawn Lines. This message will display if a material in the current plan has a problem with its pattern.
In most cases, no action is necessary because, as the message indicates, the program has reset the pattern to resolve the problem.
If you use customized material patterns, though, you may want to locate the material in question and confirm whether the default pattern definition will meet your needs.
