I want to create a brochure/flyer or post a portfolio of my plans on my website with some nice floor plan images. How can I create a 2D plan view with some rendered 3D characteristics like flooring, furniture, and appliances?
![Furniture and other objects are placed into a floor plan for visual purposes Floor plan image with textures displayed](https://d2haqc5836ials.cloudfront.net/live/KB-01142/1142-featured-13.jpg?1636153038)
One technique for creating the image above is to overlay a floor plan view on top of a camera view.
To create the top down view displaying textures
the plan that you would like to create this type of image from.
- Select 3D> Create Orthographic View> Orthographic Floor Overview
to create a 3D camera view of your structure.
- Navigate to 3D> View Direction> Top View
to reorient the view facing downward.
![Top View direction of a structure](https://d2haqc5836ials.cloudfront.net/live/KB-01142/1142-fig1-12.jpg?1636153038)
- Navigate to 3D> Rendering Techniques> Standard
to change the rendering technique and show the material textures in the view.
![Standard rendering technique applied to a camera view](https://d2haqc5836ials.cloudfront.net/live/KB-01142/1142-fig2-12.jpg?1636153038)
and remove any checkmarks from the Display column for layers you don't want to see in the view.
Once everything is displayed to your liking, you are ready to send the camera view as well as the floor plan view to a layout.
To send the top down view and a floor plan view to layout
- With the 3D camera view exactly how you want it, navigate to File> Send to Layout
- Specify any options here, such as the Layout you'd like to send it to, the Page Number, and the Scaling, then click OK.
![Send to Layout dialog](https://d2haqc5836ials.cloudfront.net/live/KB-01142/1142-fig3-12.jpg?1636153038)
- Next, navigate to your floor plan, select Tools> Layer Settings> Display Options
from the menu, and turn off any layers in the floor plan that are unnecessary to the end picture
This is a great time to modify the color of the room labels to your liking. This can easily be done by changing the line color of the "Room Labels" display layer within the layer set that is being used for this process.
- Once the floor plan is to your liking, proceed to send the floor plan over to a layout by selecting File> Send to Layout
It is important that you specify the scale to be the same as the 3D camera view that you sent in Step 1 above.
- Use the Move
edit handle along with the Point to Point Move
tool to move the floor plan so it's aligned with the 3D camera view.
![Floor plan that is overlayed on top of a camera view](https://d2haqc5836ials.cloudfront.net/live/KB-01142/1142-fig4d-12.jpg?1636153038)
- Now you can continue to send views over to this layout file and Print
it out, or you can export it by going to File> Export> Export PDF
or File> Export> Export Picture
![Brochure with for sale information](https://d2haqc5836ials.cloudfront.net/live/KB-01142/1142-fig5b-12.jpg?1636153038)
