Creating a Fire or Flame
Reference Number: KB-01830
Last Modified: July 20, 2021
Chief Architect contains several fire materials, however, they are just images. How can I make these look more realistic?
Flames inside of a firepit
Creating a 3D flame in Chief Architect is very simple. The first thing you need is a shape with only a few surfaces for the flame material to be applied to.
In this example we will create the curling flame shown above by applying a fire texture to a hollow cylinder.
Creating the cylinder
  1. In a new plan, select Build> Primitive> Cylinder , then click and drag in floor plan to create a simple cylinder shape.
  2. Once the cylinder has been created, go to  3D> Create Perspective View> Perspective Full Overview .
  3. Next, use the Delete Surface  tool hide the two end surfaces of the cylinder.
  4. Click Tools> Symbol> Convert to Symbol , choose Geometric Shapes as the Symbol Category, and click OK.
  5. Now place your new shape into a plan and resize it as needed.
  6. Apply a fire material, found in the library under Chief Architect Core Catalogs> Materials> Fire.
    Using this method, you can use different shapes to make your flame look however you'd like for your camera views.
