How do I display door and window opening indicators in an elevation view?
Opening indicators can be displayed when using the Vector View rendering technique by toggling the "Opening Indicators" layer on in the Layer Display Options or Active Layer Display Options side window.
Starting in X13, additional options relating to opening indicators can be defined on the Opening Indicators panel of the Window or Door Specification dialog.
You can also make the following modifications within the Default Settings for all windows in a given plan, or for specific door types.
By default, opening indicators for hinged openings will point to the hinge side. To change this, you can uncheck the "Openings Indicators Point to Hinge Side" setting located in the General Plan Defaults in X13 and newer, or select the "Opening Indicators Point to Handle Side" preference located on the Architectural panel of the Preferences dialog in X12 and prior.
