I adjusted the materials of an object. How can I restore the default material to this object?
Default materials can be restored using the Specification dialog or Material Painter.
To restore default materials using the Specification dialog
tool, click on an object you'd like to restore the default material to, then click the Open Object
- On the Materials panel of the Specification dialog that displays, click on the name of the component that you would like to change, then click the Select Material button.
![Materials panel of the Wall Specification dialog](https://d2haqc5836ials.cloudfront.net/live/KB-03182/3182-MaterialsPanel-15.png?1701210000)
- In the Select Materials dialog, check the Use default material box, then click OK.
![Checking the Use default material box at the bottom of the Select Material dialog](https://d2haqc5836ials.cloudfront.net/live/KB-03182/3182-SpecificationUseDefaultMaterials-15.png?1701210000)
- Click OK to close the dialog and apply the change.
To restore default materials using the Material Painter
Select 3D> Create Perspective View> Full Camera
view and create a camera view looking at the object that you want to restore the default material to.
Navigate to 3D> Material Painter> Material Painter
- In the Select Materials dialog that displays next, check the Use default material box, then click OK.
![Checking the Use default material box at the bottom of the Select Material dialog](https://d2haqc5836ials.cloudfront.net/live/KB-03182/3182-CameraUseDefaultMaterial-15.png?1701210000)
- Click on the object in the camera view that you want to return to its default material. The view will update and the default material will be restored to the surface/object that you clicked on.
