What are layers, and how are they used in Chief Architect and Home Designer?
It can be helpful to think of each layer in the program as a transparency sheet on which objects are drawn. Each object in the program is assigned to a layer, and nearly all views in the program use multiple layers, like stacking transparency sheets together.
Layers are used to stay organized, as well as to increase efficiency by allowing you to quickly change how (or whether) a group of objects are collectively displayed, rather than changing the display of objects one-by-one.
![Plan view exploding into its component layers](https://d2haqc5836ials.cloudfront.net/live/KB-03183/3183-ExplodingPlanView-15.gif?1706642583)
You can quickly see which layer an object is on by selecting the object and looking in the Status Bar at the bottom of the program.
You can learn more about layers in the following sections:
To toggle the display of a layer
the plan in which you would like to toggle the display of a layer.
- From the menu, select Tools> Layer Settings> Display Options
In Home Designer, select Tools> Display Options
instead.
- In the Layer Display Options dialog that opens, you'll see a list of all available layers in the current plan. Scroll to the target layer and click in the Disp column for that layer to toggle its display on or off.
![Mouse pointer in the Disp column of the Layer Display Options dialog](https://d2haqc5836ials.cloudfront.net/live/KB-03183/3183-LayerDisplayOptionsDisp-15.png?1706642583)
- Click OK to confirm your changes and close the dialog.
In Chief Architect Premier, layers are organized into multiple Layer Sets to further improve efficiency. For more information on Layer Sets, please see the Related Articles section below.
To change the properties of a layer
instead.
- In the Layer Display Options dialog that opens, scroll to the target layer, then click in the Color column for that layer to change its color.
In Home Designer Pro and Chief Architect Premier, you can also select a layer, then use the Properties for Selected Layer section to change the Color, Line Weight, Line Style, Text Style.
In Chief Architect Premier only, you can double-click on the Name of a layer to rename it.
In this example, the color and line style of the "Roof Planes" layer is changed.
![Changing the color and line style of the Roof Planes layer in the Layer Display Options dialog](https://d2haqc5836ials.cloudfront.net/live/KB-03183/3183-LayerDisplayOptionsColorLineStyle-15.gif?1706642583)
To lock or unlock a layer*
*Available in Home Designer Pro and Chief Architect Premier only.
Objects on a locked layer cannot be selected.
In Home Designer Pro, select Tools> Display Options
- In the Layer Display Options dialog that opens, scroll to the target layer and click within the Lock column or Lock checkbox toggle the lock status on or off.
![Locked "Roofs, Gutters" layer selected in the Layer Display Options dialog](https://d2haqc5836ials.cloudfront.net/live/KB-03183/3183-LayerDisplayOptionsLock.png?1706642583)
Some layers that are locked by default include:
- Roofs, Gutters
- Roofs, Overhang Area
- Roofs, Ridge Caps
- Roofs, Trim
To change an object's layer**
**Available in Chief Architect Premier only.
tool, click on the target object, then click on the Open Object
- In the object's Specification dialog, select the Layer or Line Style panel.
- Using the Layer drop-down menu, select the layer you want to assign the object to.
![Layer drop down in the Line Style panel of the Line Specification dialog](https://d2haqc5836ials.cloudfront.net/live/KB-03183/3183-LineStyleLayer-15.png?1706642583)
- Click OK to confirm the change and close the dialog.
There are other ways to change an object's layer, such as using the Layer Painter and Layer Eyedropper tools. For more information, please see the Related Articles section below.
To create a new layer**
- In the Layer Display Options dialog that opens, click the New button to open the New Layer dialog and give it a name. Layers must have unique names, so if you try to give a new layer the same name as an existing layer, the program will prompt you to give it a different name.
![New Layer dialog](https://d2haqc5836ials.cloudfront.net/live/KB-03183/3183-NewLayer-15.png?1706642583)
- Once a name is specified and you click OK, the newly created layer will be selected in the Layer Display Options dialog, and you can specify its properties as desired.
To create a new layer that has the same properties as an existing layer, select a layer and click the "Copy" button, then rename and modify the properties of the new layer as desired.
To delete a layer**
- In the Layer Display Options dialog that opens, scroll to the target layer and on it to select it.
- Click the Delete button to delete the selected layer.
