Replacing Fonts
Reference Number: KB-00006
Last Modified: July 15, 2024
When I open my plan or layout, a dialog appears with the following message:
  • "#272032451 - The following (default) fonts are not available on this system. Missing fonts can lead to unpredictable text sizes." How do I resolve this?
OR
I am using Chief Architect X15, Home Designer 2024, or a newer version, and would like to replace a used font with another font within my project. Is there an easy way to do this?
Chief Architect uses the fonts that are located in your Fonts folder on a Windows system or in the /Library/Fonts/ and ~/Library/Fonts folder locations on a Mac.
When this dialog appears, Chief Architect is unable to find a font that is being referenced in the file that you're opening. You can either choose to replace the font with another font that you do have installed using the Replace With drop-down or leave it set to "No Change" to maintain the file's association with the missing font. If you select "No Change," we recommend installing the missing font so that there are no discrepancies between saved versions of files. More information on installing fonts can be found in the linked resources:
For best printed results, using true-type or open-type fonts is recommended.
In Chief Architect X15, Home Designer 2024, and newer versions, a used font can be replaced with another font at any time using the Replace Fonts dialog.
Note: Please be aware that the Windows and macOS operating systems render fonts differently on-screen, using different row and character spacing. Even when all fonts are present, the text in a given file may look different on different systems.
Replacing fonts in Chief Architect X15, Home Designer 2024, and newer versions
  1. With a file open, navigate to Edit> Replace Fonts  from the menu.
  2. In the Replace Fonts dialog that displays:
    • Click on a font name in the list to select it. Use the Shift or Ctrl key to select multiple fonts.
    • Select a replacement font using the Replace With drop-down. A preview of the selected font will display at the bottom.
    • Click OK.
CHIEF ARCHITECT FONTS
The ChiefBlueprint font is installed to the Fonts folder on a Windows system when a Chief Architect program is installed, and can be used in any application. On a Mac, this font is embedded with the Chief Architect program, but is not installed on the system. If you would like to use this font style in other applications on your Mac, please download the ChiefBlueprint attachment below, extract it, and follow the instructions in the macOS resource above to install it to your system.
CityBlueprint and CountryBlueprint are additional font styles that were part of the Chief Architect installation in X10, Home Designer 2019, and prior program versions. These font styles are supplied here for legacy purposes only.
