When I create a Full Overview, the image that is generated is much smaller than it used to be, or the view appears blank. Why is this occurring?
When generating a 3D Full Overview or Floor Overview camera view, the program will look at all of the objects that are set to display in that view. So if you have an object in the distance that may be significantly smaller in regards to the relationship to the actual structure in the plan, the program will generate the view to include that object, but it may be difficult to see.
If you delete the stray object, or move it closer to the structure, and then recreate the camera view, it will display normally.
A Terrain Perimeter is included when you create an Overview, so if your terrain is quite large, and your house is small in comparison, consider using a normal Camera instead of an Overview to create your views
To locate the stray object(s)
- Launch Chief Architect and Open
the plan that is exhibiting this behavior.
- If it's not already open, navigate to View> Active Layer Display Options
to turn on the display of this side window, then select the All Layers ON option using the Layer Sets drop-down.
- On the floor you are taking an Overview view of, select Window> Fill Window
or press the F6 key to view everything on screen that is visible. If you are zoomed in so close that only a portion of the view displays on screen, selecting Fill Window
zooms out so that the entire view fits on the screen, which will include the stray object(s), allowing you to more easily locate them.
If you do not initially find the object(s), follow the same procedure on the Foundation and any other floors of your plan.
We can see in the image below that the stray object is located in the upper right corner of the plan.
- Zoom in on the area to locate the object(s) using either the scroll wheel on your mouse or the Zoom
tool.
- Next, use the Select Objects
tool to select the stray object(s).
If multiple rogue objects exist, left-click and drag using the left mouse button to create a selection marquee.
- Once selected, use either the Delete
edit button or the Delete key on your keyboard to remove the object(s).
- Click on the Fill Window
option again to ensure that the structure now appears as expected.
- Switch back to the original layer set that was used for this plan view using the Active Layer Display Options
If you are unable to locate the stray object(s), please contact Technical Support using the Technical Support Center.
