I have created a custom shaped 3D/Polyline Solid and would like to add it to the library browser so that I can use it in future plans. How can I accomplish this task?
A 3D/Polyline Solid can easily be added to the User Catalog in X15 and newer versions using the Add to Library edit tool. However, in X14 and prior versions, a 3D/Polyline Solid must first be converted to an architectural block before it can be added to the User Catalog in the library browser.
To add a 3D/Polyline Solid to the library browser in X15 and newer versions
tool, click on the 3D/Polyline Solid that you want to add to the User Catalog.
- With the solid selected, click the Add to Library
- The solid can now be found in the User Catalog and can be edited at anytime by right-clicking on the object's name, and selecting Open Object
from the contextual menu.
To add a 3D/Polyline Solid to the library browser in X14 and prior versions
- Use the Select Objects
tool to drag a marquee around the 3D/Polyline Solid.
- With the selection marquee created, click on the Make Architectural Block
- Once you have blocked the solid, click on the Add to Library
edit tool to add the object to the User Catalog.
- If you use this 3D/Polyline Solid in a future plan, and find you need to modify it, simply select it again and click on the Explode Architectural Block
edit tool to make modifications.
