I have placed a bay, bow, or box window using these tools in Chief Architect. Now, how can I modify the individual component windows that are part of the unit?
A component window within a bay, box, or bow window can be resized like any other standard window. The steps below can be done either in the 2D floor plan view, a Cross Section/Elevation view, or in a 3D camera view to modify component windows of an automatic bay, bow, or box window.
Modifying component windows
tool, click at the location of the component window that you would like to modify. The entire window unit will be selected.
In this example, we have clicked on the first component in a bay window unit, as shown in the image below.
![Bay window selected](https://d2haqc5836ials.cloudfront.net/live/KB-00448/448-BayWindow-13.png?1644266040)
- Click the Select Next Object
edit button or press the Tab key on your keyboard to cycle to the component window.
![Individual component is selected.](https://d2haqc5836ials.cloudfront.net/live/KB-00448/447-Component-13.png?1644266040)
- Once selected, click on the Open Object
edit button to display the Window Specification dialog, make any desired changes, then click OK.
![General panel of the Window Specification dialog](https://d2haqc5836ials.cloudfront.net/live/KB-00448/448-fig3-14.png?1644266040)
- If you you like to edit a different component window for a bay or box unit, repeat the procedure until all of the windows have been adjusted to your liking.
Exploding Bay, Bow, or Box Windows*
*Available in X14 and newer program versions
tool, click on the bay window unit to select it.
![Selecting the bay window in plan view](https://d2haqc5836ials.cloudfront.net/live/KB-00448/448-fig4-14.png?1644266040)
- Click the Explode Bay/Bow Window
tool to separate the window unit into separate components.
tool, click on the component that you want to change.
![Window Specification on the General panel](https://d2haqc5836ials.cloudfront.net/live/KB-00448/448-fig5-14.png?1644266040)
- Continue selecting the objects you want to change and use their specification dialogs to make adjustments.
