I would like to add GFCI outlets to my plans. How do I do this?
GFCI (ground fault circuit interrupter) outlets can be added to your plans using the dedicated GFCI Outlet tool in X13 and newer versions, or by locating and placing the GFCI library symbol in X12 and prior versions.
To add GFCI outlets in X13 and newer versions
from the menu, expand the Electrical category, select the General Electrical subcategory, then click Edit.
![Default Settings dialog with the General Electrical category selected](https://d2haqc5836ials.cloudfront.net/live/KB-00493/493-DefaultSettings-13.png?1628813687)
- In the Electrical Defaults dialog, select each of the Outlet - GFCI options that are located in the Default Library Objects list, verify that an appropriate symbol is chosen for each, then click OK and Done to close the dialog boxes.
![Electrical Defaults dialog with Outlet - GFCI selected](https://d2haqc5836ials.cloudfront.net/live/KB-00493/493-ElectricalDefaults-13.png?1628813687)
- Next, select Build> Electrical> GFCI Outlet
, then click in your desired location to place an outlet.
![GFCI outlet placed on a wall in a plan view](https://d2haqc5836ials.cloudfront.net/live/KB-00493/493-GFCI-13.png?1628813687)
Much like the other Outlet tools, the GFCI Outlet
tool can place receptacles on walls, the floor, and on the sides of cabinets and soffits.
Existing 110V outlets can also be converted to GFCI outlets using the Change to GFCI Outlet
edit button. The reverse of this can be accomplished using the Change to 110V Outlet
Additional outlet symbols can be located in the Library Browser by navigating to Chief Architect Core Catalogs> Mechanical, Electrical, Plumbing> Electrical> Outlets.
To add GFCI outlets in X12 and prior versions
- If the Library Browser is not already open, navigate to View> Library Browser
, then browse to Chief Architect Core Catalogs> Mechanical, Electrical, Plumbing> Electrical> Outlets> Surface Mounted> 110V.
![Browsing to the Outlets folder in the Library Browser](https://d2haqc5836ials.cloudfront.net/live/KB-00493/493-LibraryBrowser-12.jpg?1628813687)
- Select the GFCI outlet symbol from the library, then click along a wall or cabinet to place it.
![GFCI outlet placed onto a wall](https://d2haqc5836ials.cloudfront.net/live/KB-00493/493-LegacyGFCI-13.png?1628813687)
