How do I create flared stairs and stairs with curved treads?
In Chief Architect, both flared stairs and stairs with curved treads can be created easily using the Flare/Curve Stairs edit tool.
Flared stairs grow wider near one end, typically sweeping outward at the bottom. Stairs can also be flared at the top or on both ends.
To create flared/curved stairs
- Select Build> Stairs> Draw Stairs
from the menu, then click and drag to draw a staircase.
- Click on the staircase to select it, then click the Open Object
- On the General panel of the Staircase Specification dialog that opens, make your desired changes to the Length, Width, and other properties/fields located here, then click OK.
It's generally best to have these structural aspects of the stairs finalized before making them flared.
For finer control of the fields located here, you may want to adjust the Tread Depth radio button and/or uncheck the Automatic Heights box under the Section Heights section.
- With the staircase selected, notice the edit handles that display.
- The Sizing
handles on each edge allows you to resize it.
- The Move
handle at the center lets you relocate it.
- The triangular Rotate
handle lets you change the direction.
- With the staircase still selected, click the Flare/Curve Stairs
- Notice the new set of edit handles that now display on the staircase.
To create a flare with specific measurements
If you would like to create a flare with a specific chord and radius, first draw the desired arc using the CAD drawing tools for use as a reference. While it isn't possible to specify a staircase with this exact information, you can model it closely and display an annotation with the desired measurements
The steps below describe how the arc of a flare can be defined. The same tools can be used to define the arc of a curved tread, as well.
- Create a staircase as described in Steps 3 and 4, above.
from the menu, then click and drag three lines:
- One line extending from the front edge of the stairs.
- A second line running parallel to the edge you wish to flare.
- A third line running parallel to the first but closer to the staircase center.
- Click on the second CAD line, running parallel to the stair edge, move you mouse over the dimension until the Pointer
cursor displays, then click on the temporary dimension that displays.
- In the Move Object Using Dimension in-line text box, specify the desired distance that you would like the flare to extend at its widest point, then click Enter on your keyboard to move the line the specified distance from the stairs.
- If a temporary dimension does not display when you click on the line, either it is not exactly parallel to the stairs, or Temporary Dimensions are toggled off. Select View> Temporary Dimensions
from the menu to turn this feature on, then try again.
- Repeat this process with the third line drawn in step 3, this time specifying the length down the stairs that you would like the flare to extend.
- Select CAD> Points> Place Point
from the menu, then click once at the point where the first and second lines meet, and once where the third line meets the edge of the staircase.
- These two points indicate where the flare's arc will begin and end.
- For accurate placement, be sure that Object Snaps
are enabled.
tool, click on each of the CAD lines drawn in Step 3 and Delete
them.
- Select CAD> Arcs> Draw Arc
from the menu, then click and drag an arc beginning on one CAD point and ending on the second one.
- Click on the arc to select it, then click the Open Object
- On the General panel of the Arc Specification dialog:
- Click the radio button beside Chord to lock the arc's direction.
- Specify the desired Radius or End Angle for this arc.
- Click on the staircase to select it, then click the Flare/Curve Stairs
- Use the flare edit handle to extend the front edge to meet the CAD point.
- Use the side and center edit handles closest to the flare to adjust its curve so that it closely matches that of the CAD arc.
- Once the flare is exactly to your liking, de-select the staircase.
- Select CAD> Points> Delete Temporary Points
to delete the points.
- To display the length of the chord and its radius, select the CAD arc, click the Open Object
edit button, and on the Line Style panel of the Arc Specification dialog, check the box beside Show Length, then click OK.
