I'd like to create a solid wall that follows the slope or angle of the stairs, but also has a railing on top of it. Is this possible?
Stair rake walls can be created using a railing that is set to be a pony wall, and then enabling the Follow Stairs setting.
It's important that you don't create or move the railing beneath the stairs. If you're having trouble precisely placing the railing beside the stair section, navigate to Edit> Snap Settings and ensure that your Object Snaps are enabled.
Creating a manual railing that follows the slope of the stairs, like shown in this example, may override the automatically generated stair railings, depending on the height that is set for the lower framed wall type.
Several railing and wall variations can be created alongside stairs. For example, you may want a railing to follow the angle of the stairs, but then die into a full height wall. Please view the Stair Wall Options: Partial Railing, Wall Under Stairs, Stairwell video to learn more.
