What is the best way to create a stairwell in the program?
    When stairs are created in Chief Architect, they begin on the current floor and draw in an upward direction. The program seeks the exact height of the floor above and will snap to that height if at all possible; and, it will produce stairs with consistent treads and risers in the process.
    There are a couple of ways to create a stairwell, an opening in the ceiling that allows the staircase to reach the floor above. The easiest is to use the Auto Stairwell tool; however, it is also possible to create a stairwell manually.
 from the menu, then click and drag a length of stairs in floor plan view.
 from the menu, then click and drag a length of stairs in floor plan view.   edit button.
 edit button to create an opening in the floor above.
 edit button to create an opening in the floor above.Note: The Auto Stairwell tool will only be available if a room exists on the floor directly above the staircase, and it does not already have its room type set to Open Below.
 from the menu or press the F9 key on your keyboard to turn on the Reference Display. This allows you to see walls and other objects, including stairs, that are located on another floor.
 from the menu or press the F9 key on your keyboard to turn on the Reference Display. This allows you to see walls and other objects, including stairs, that are located on another floor.   or Build> Railing and Deck
 or Build> Railing and Deck  , choose your desired wall or railing tool, then draw a room around the red outline associated with the staircase.
, choose your desired wall or railing tool, then draw a room around the red outline associated with the staircase.  from the menu, then click on the railing at the top edge of the stairs to place a doorway opening on that edge if one does not already exist, then resize the doorway as needed.
 from the menu, then click on the railing at the top edge of the stairs to place a doorway opening on that edge if one does not already exist, then resize the doorway as needed.   edit button.
      *Applies to X16 and newer versions.
 tool.
 tool.Note: Landings that are part of a staircase will not be added to the library. Complete stair configurations will also not be added to the library.
 edit button to add them to your User Catalog for future use.
