How do I create a room or closet space under a staircase?
Many plans use the space beneath staircases for storage or utility closets. When walls are drawn under a staircase in Chief Architect, the walls will be cut off automatically by the stairs making it easy to create a room in this area.
To create a room under a staircase
- Draw your staircase to your specifications using the Stair tools.
In this example, an L-shaped staircase is created.
- Select Build> Wall> Straight Interior Wall from the menu.
- Draw the interior walls beneath the stairs so that the surface of the walls align with the outer edge of the staircase.
In this example, the newly drawn walls have been highlighted green in the image below.
- Using the Select Objects tool, select the staircase and click the Open Object edit button.
- On the Style panel of the Staircase Specification dialog that opens, uncheck the box next to Open Risers, check the box next to Open Underneath, then click OK.
You can also set the Pattern Type to "No Pattern" on the Fill Style panel if you would like to see under the staircase in floor plan view. Please see the Related Articles section to learn more.
- Select Build> Door> Hinged Door from the menu, and click on one of the interior walls you just drew to place a door to your room.
