I would like to create a wrapped opening, or doorway, in my plan. How can I accomplish this task?
You can create a wrapped opening by placing a doorway and removing the casing and jamb.
Wrapped openings can also be created using the Pass-Through tool. However, since pass-throughs are classified as windows, the interior casing, frame, and lintel will need to be removed to create a similar effect.
