Using the Cross Section Slider
Reference Number: KB-00631
Last Modified: February 12, 2025
How do I create a dynamic sectional view of my structure that I can resize and change?
Cross Section Slider View
An adjustable cross section view can be created while in a camera view using the Cross Section Slider tool.
To use the Cross Section Slider
  1. In your plan, navigate to 3D> Create Perspective View> Perspective Full Overview to create an overview of your plan.
    Other Perspective Camera  and Orthographic Camera  tools can be used as well.
    Note: The Cross Section Slider is not available in Cross Section/Elevation, Backclipped Cross Section, and Wall Elevation views. Additionally, it's not available when using the Vector View rendering technique in X15 and prior program versions.
    Perspective Full Overview of a structure
  2. While in the camera view, select 3D> Camera View Options> Cross Section Slider to open the Cross Section Slider dialog.
    Cross Section Slider with no cutting planes enabled
  3. Check the box beside a cross section cutting plane, then either use the slider or enter a desired value using the text field.
    Note: The cutting plane position is measured from the edge of the model that is cut first by the selected cutting plane.
    Single cutting plane enabled in the Cross Section Slider
  4. You can also enable multiple cutting planes, and adjust each of them accordingly.
    Multiple cutting planes enabled in the Cross Section Slider
  5. Click OK when you're finished making changes. If the active camera is saved, its Cross Section Slider settings will also be retained.
    Camera views can be saved by navigating to Tools> Active View> Save Active View .
