What does the Screen Capture tool do, and how do I use it?
The Screen Capture tool allows you to add backdrops, images, and materials directly to the library, as well as create picture objects. You can capture screens from within Chief Architect, from a web page, or in other programs.
To create a screen capture
Select
Tools> Screen Capture> Screen Capture Setup
In the
Screen Capture Setup dialog that appears, select an appropriate option in the Save Capture As section.
Click the Capture button when you are ready to proceed.
Click and drag a selection marquee of what you wish to capture.
To create another screen capture of the same type, select
Tools> Screen Capture> Capture Screen
To use a captured backdrop
Select
Edit> Default Settings
, expand the
Camera Tools category, select a camera tool you would like to apply a backdrop to, then click
Edit.
On the Backdrop panel of the Defaults dialog that displays, click the Select Backdrop button.
In the
Select Library Object dialog that displays, select the captured backdrop located in the User Catalog, then c
lick OK.
This image will now be used as the backdrop for views created using this particular tool going forward.
You can also apply a backdrop to an existing camera view. While in your desired camera view, navigate to Tools> Active View> Edit Active View, then access the Backdrop panel.
To use a captured material
- Select an object that you want to apply the captured material to and click the Open Object
- On the Materials panel of the object's Specification dialog, click on the name of the component that you want to apply the material to.
- Click the Select Material button to display the Select Material dialog and choose the captured material located in the User Catalog.
- Click OK on each dialog to confirm the change.
To use a captured image
to open the Library Browser if it's not already open.
- Browse to the User Catalog, select the captured image, then click in your desired location to place it in the plan.
This image will now be visible in 3D Camera
views.
