PROBLEM
I'm receiving several error messages when I open or close the program. These include one or more of the following:
- "#272032377 - Could not write to your program data folder. Resetting it to default. You can change it in Preferences > General > Folders."
- "#272029301 - Attempting to write the Master List file. Unable to write to the directory. The file cannot be saved"
- "#272001053 - Cannot open toolbar configuration file to store the toolbar information in the program."
- "#272032139 - The toolbar file could not be saved. It may be read only."
- "#272032238 - Your hotkeys configuration could not be loaded. The default configuration will be used instead."
- "#272032291 - Cannot open file."
- "#272032141 - The file appears to be locked. This could be the result of another user or program using the file. This may also result from having insufficient privileges to access this file."
- "#272004609 - Couldn't find default electrical object. Please check your electrical defaults to make sure all of the defaults are set to a valid object."
- "#272032391 - The data file does not have write privileges."
Why are these errors occurring?
SOLUTION
This behavior may present itself if the program doesn't have access to the files or locations mentioned in the error messages. This can occur if the Controlled Folder Access setting is enabled for Chief Architect programs on a system with Windows installed, or if the Full Disk Access setting is disabled for Chief Architect programs on a system with macOS.
Please follow the instructions below to ensure that the program has proper access to the files it needs to operate.
Adding Chief Architect/Home Designer as an allowed app in Controlled Folder Access*
*This applies to computers running Microsoft Windows.
Save
your work and close out of the Chief Architect/Home Designer program.
- Using Windows Search, type
Ransomware protection
and click on the system setting option that is listed.
![Search ransomware protection in Windows Search](https://d2haqc5836ials.cloudfront.net/live/KB-03125/3125-RansomwareSearch-14.png?1716411286)
- Click on Allow an app through Controlled folder access.
![Click on Allow an app through Controlled folder access](https://d2haqc5836ials.cloudfront.net/live/KB-03125/3125-AllowAnApp-14.png?1716411286)
- On the next screen, click on Add an allowed app.
- Click on Recently blocked apps and in the window that appears, click the + symbol next to the Chief Architect/Home Designer program.
![Click the plus sign to add Chief Architect or Home Designer to the allowed apps list](https://d2haqc5836ials.cloudfront.net/live/KB-03125/3125-Add-16.png?1716411286)
- The program will then be added to the allowed apps section.
![Chief Architect is now an allowed app](https://d2haqc5836ials.cloudfront.net/live/KB-03125/3125-ProgramListed-16.png?1716411286)
- Launch the Chief Architect/Home Designer program.
If one or more of the errors mentioned above continue to appear when opening the program, please contact our Technical Support team directly for further assistance.
Full Disk Access is disabled for Chief Architect/Home Designer*
*Applies to Apple macOS machines running macOS Catalina 10.15 or newer.
Save
- Open the Apple
menu and select System Settings.
In macOS Monterey 12 and prior, this was called System Preferences.
- Click on the Privacy & Security category.
In macOS Monterey 12 and prior, this was called Security & Privacy.
- Locate the Full Disk Access option and select it.
In macOS Monterey 12 and prior, click on the Privacy tab at the top, then click on Full Disk Access.
- Allow the Chief Architect/Home Designer program full disk access by enabling the toggle or checking the box to the right of the application.
![Enabling Full Disk Access for the Chief Architect/Home Designer program](https://d2haqc5836ials.cloudfront.net/live/KB-03125/3125-Mac-16b.png?1716411286)
If the Chief Architect/Home Designer program is not listed in this section, select the Add + sign to open Finder and select the Chief Architect/Home Designer program from the Applications list.
