When I try to open or save a particular file, I receive one of the following error messages:
What do I do?
There are a couple of broad reasons why one of these errors might occur:
The best way to resolve this issue will depend on the cause.
If you receive the first error message mentioned above, the Chief Architect or Home Designer program may not have access to the file you are attempting to open. This can occur if the Controlled Folder Access setting is enabled for Chief Architect programs on a system with Windows installed, or if the Full Disk Access setting is disabled for Chief Architect programs on a system with macOS. To resolve this behavior, please refer to the "Troubleshooting Error Messages Associated With the Program's Data Folder" resource in the Related Articles section.
If you receive the second or third error message mentioned above, check to make sure that you have a reasonable amount of free/available storage space. If you don't have at least 5 GB of available space, please access the appropriate resource below to learn how to free up space on your system:
There are several scenarios in which a Chief Architect file that you wish to open might already be in use elsewhere. It could, for example, be:
The first of these scenarios is easy to resolve - if another version of Chief Architect or Home Designer is running, simply save your work and close the file. The second scenario requires a little bit of investigation. Save your work, close your Chief Architect program, then navigate to the appropriate section below that corresponds to your operating system. The third scenario means that the file may be stored in a shared location on this computer or on another system that is connected to your local area network, and the file is being used or edited by another process on that system.If the file is locked because another user on the same network has it open on their system, then you can have them close the file so that you can open it. If it is locked and does not appear to be in use on any other systems, restart all the computers that are connected to the network and try opening it again.
Working on files from a shared location or external storage device can cause problems, such as slow performance and file corruption/data loss. As a best practice, we recommend copying projects to a local file location on your computer while working on them. After you're done working on the file, close the program, then copy the file back up to the shared location. Please see the "Sharing Projects in a Work Environment that is Utilizing Cloud/Network Services" resource in the Related Articles section to learn more.
Microsoft Windows:
Apple macOS:
If you are sure that the plan or layout file is not already in use elsewhere, then it is likely that your user account for this system does not have sufficient rights to access the file where it is currently saved.
One way to avoid this issue is to have the user that created the file(s) copy them to a location that you have access to - for example, the Public user's Documents directory.
To learn more about file and folder permissions for individual users on your computer visit the Microsoft or Apple website.
