There is currently no online help available for this topic
Message boxes in Chief Architect have a Check Knowledge Base button that, when clicked, launches your web browser to a Knowledge Base article with information about the message. If there is not an article relating to the message in question, you will be directed to this page.
If you are continuously receiving an error while working on a plan or layout, please gather as much information as possible and report the issue to Chief Architect Technical Support.
To report an issue to Chief Architect Technical Support
Use the Technical Support Center to create a new Support Case, and include all of the files and information mentioned below.
- The exact wording and details of the error. Click the Details button, if available, and make a note of the error number in addition to any additional wording shown. If possible, copy the full text of the error message exactly as it's shown, or take a screenshot of the error details.
- The conditions under which the error occurred. For example, were you creating a camera view, placing objects in a floor plan view, or performing some other action?
- If the message is specific to a single plan or layout you're working on, use the Backup Entire Plan/Layout
tool to create a backup.
See Knowledge Base article: Using the Backup Entire Plan/Layout Tool.
- Locate and save the program's Message Log file.
- Export or save your System Information.
- It is possible that Technical Support may need additional information regarding the issue, which they will request via the Technical Support Center.
