When I try to center an object like a door or window on a wall, I receive the following message:
How do I avoid this problem?
This message will display when you click in a location that does not allow the program to determine which wall of a room should be used to center the object.
In order for the Center Object edit tool to work, two conditions must be met:
It is important that you don't click on the wall that you wish to center the selected object along.
The image below shows several instances of centering. The areas that the program can use to determine both the wall and the room that a door should be centered on are highlighted when using the Center Object tool.
