I would like to design my own custom muntins for a window or door. How can I do this?
Custom muntins are created by drawing their pattern using the CAD tools in a cross section/elevation view, blocking the pattern to create a CAD block, and then selecting the window or glass door and clicking on the Load Muntins edit button. The CAD block should cover at least half the glass horizontally and one quarter of the area vertically, but should not overlap the sash, frame, or casing by more than five percent in any direction.
To create custom muntins
- Launch Chief Architect and Open
the plan in which you would like to create custom muntins within.
, then create a view of the wall the window or glass door is in.
If needed, use the Zoom
tool to focus in on the window or glass door.
- Use the Draw Line
and Draw Arc
tools to design the desired muntins.
Try to make them start and end as close to the edge of the glass as possible. Keep in mind that you will want to use two arcs to create a full circle.
- When the muntin design is complete, group-select all of the lines and arcs using the Select Objects
tool, then click the Make CAD Block
(Optional) With the CAD block created and selected, click the Copy/Paste
edit button, select the Reflect About
secondary edit button, then hover your cursor over the window. When the gray dashed line meets up with the center of the window vertically, click once to create a reflected copy of the CAD block.
tool, click on the window or glass door to select it, then click the Load Muntins
edit button to convert the CAD block(s) into custom muntins.
