I have reached the review stage in my plan, and need to indicate where changes are being made. I have heard that Chief Architect has a tool for revision clouds. How does this tool work?
The Revision Cloud tool allows you to draw a closed polyline with a series of arcs or bulges displaying along each edge.
To create a revision cloud
- The easiest way to create a revision cloud is to select CAD> Revision Cloud
, then click and drag to draw a rectangular shape with edges that display a series of arcs.
- Additional ways to create a revision cloud include:
- With the revision cloud created, click on it using the Select Objects
tool and then select the Open Object
- In the Revision Cloud Specification dialog that opens:
- On the Cloud panel, adjust the arc properties to your liking. To learn more about each option listed here, click on the Help button at the bottom of the dialog.
- On the Line Style panel, adjust the layer and line properties of the revision cloud.
- On the Fill Style panel, adjust the pattern properties associated with the revision cloud.
- On the Label* panel, choose whether or not to include a label as part of the revision cloud.
*Applies to X16 and newer program versions.
- Once all changes have been made, click OK to close the dialog.
MORE INFORMATION
- Revision clouds are drawn based on the settings in the Revision Cloud Defaults dialog, and are initially placed on the layer specified there.
Multiple Revision Cloud Defaults can be setup and specified to be used with various Default Sets. Please refer to the Related Articles section below to learn more.
- Once created, revision clouds can be selected and edited much like other closed-polyline based objects. Unlike other closed polylines, however, the edges of a revision cloud are only seen when it is selected. When it is not selected, only the arcs along its perimeter are visible.
- The arcs along a revision cloud are not its actual edges and cannot be individually selected, although you can control their size and frequency. If you wish to individually edit the arcs, you need to convert it to a plain polyline.
