Can I run Chief Architect on more than one computer at a time?
OR
I receive a message stating:
What should I do?
The software is a single-user license intended for only one person. The software can be installed on as many computers as needed; however, a single software license can only be active on one computer at a time. You will need your product key and an internet connection to switch between computers. If multiple users will be using the software, you must purchase a separate license for each person. Contact our Sales team to learn more about purchasing additional licenses.
If you have already installed the software and are met with the message above, you will want to manage your license - Learn how below. If you need to install the software onto a secondary computer, you can download the program by accessing your Digital Locker.
Do note that plan and layout files that were designed and saved on one computer will need to be transferred to the secondary computer if you'd like to continue working on them. Consider utilizing the Backup Entire Plan/Layout tool prior to transferring Chief Architect files between computers.
It's also important to remember to only work on plan and layout files that are saved on your local machine's hard drive. Working on files over a network server, external hard drive, cloud storage service, or USB flash drive is not recommended, as file corruption and data loss can occur.
Deactivating a license on any particular machine does not affect a rental plan or auto renewal process for payment. If you would like to stop your rental, please contact our Sales team.
If you're unable to activate or deactivate your license, or require further assistance, please contact our Customer Service team.
