How can I move walls precisely using dimensions?
Temporary dimensions will display along the length of a wall as it is drawn, helping you draw walls to the desired length. Although dimensions display as you are drawing, you do not need to position walls precisely when you first draw them as they can be easily moved into place at any time.
To draw the structure and precisely move walls using temporary dimensions
- In a new file, select Build> Wall> Straight Exterior Wall
, then in a clockwise fashion, click and drag out walls to create a basic structure.
- Once you have created your structure, use the Select Objects
tool to select the left wall. Notice that two temporary dimensions display: one displaying length of the selected wall, and one displaying the distance between the wall that is parallel to it.
You can also change how temporary dimensions locate walls when they are selected. For example, you may want temporary dimensions to locate a wall's surface (Drywall) instead of a wall's dimension layer (Framing). Navigate to Edit> Default Settings, expand the Dimension category, select Temporary Dimensions, then click Edit to change how temporary dimensions locate walls.
- With the left wall selected, move your cursor over one of the dimensions displayed and you will notice that the cursor turns into a pointing hand cursor
- Once you see the cursor change, left click once on the dimension to edit it.
- Enter a new value and tap the enter key on your keyboard to close the text field and apply the change. The selected wall will move until the specified distance is reached.
In this example, we entered a value of 25'.
Numbers entered with an apostrophe denote feet and the numbers entered with quotes denote inches. If neither apostrophes nor quotes are included, the entered value defaults to inches.
- Repeat this process for the remaining exterior walls as necessary, continuing in a clockwise direction.
To precisely move walls using other dimensions
- Other dimensions, such as those created using the Auto Exterior Dimensions
tool, and the various tools found by navigating to CAD> Dimensions
, can also be used to move walls in your plan.
- You can use the same procedure of selecting a wall, clicking a controlling dimension, then entering the exact value you want this dimension to be.
If you are not sure which dimensions are controlling dimensions, you can identify these by moving your cursor over the dimensions. When your cursor turns to a hand
, you are over a controlling dimension for the selected wall.
- As when using temporary dimensions, you will want to continue in a clockwise direction when moving exterior walls.
Although not as critical when moving interior walls, it's important to note that interior walls have a primary wall side that dimensions will prioritize when an interior wall is selected.
