Creating an Arched Parapet Wall
Reference Number: KB-01958
Last Modified: April 23, 2025
How do I create and generate framing for a parapet wall that has an arch?
An arched parapet wall can be created by using a curved roof plane.
You can create an arched parapet wall by building a new 2nd floor, adjusting the height and materials as needed, and then modifying the front parapet wall using a roof plane.
Begin by opening the plan in which you would like to create an arched parapet wall. In this example, a simple 30' x 40' rectangular structure with a basic foundation will be used.
To create parapet walls
  1. The roof area with parapet walls will be created using an additional floor, so select Build> Floor> Build New Floor  from the menu.
  2. In the New Floor dialog, choose Derive new 2nd floor plan from the 1st floor plan option and click OK
  3. On the Structure panel of the 2nd Floor Defaults dialog, which opens next:
    Make changes to your ceiling height and floor finish in the 2nd Floor Defaults.
    • Set the Rough Ceiling value to equal the height you would like your parapet walls to be.
      In this example, a value of 36" is specified.
    • Remove the checks from Roof Over This Room and Flat Ceiling Over This Room.
    • Click the Edit button next to Floor Finish to open the Floor Finish Definition dialog.
      In the Floor Finish Definition dialog set your floor finish to your desired material and thickness.
      • Select the topmost layer, click in the Texture box, select an appropriate flat roofing material, then click OK.
      • Add and/or remove any additional layers, as desired.
      • Click OK.
  4. Next, access the Moldings panel and click on the Delete button to remove the base molding from the 2nd floor.
    In the 2nd Floor Defaults remove the default base molding.
  5. Click OK, then create a Camera  view to see the results so far.
    Take an overview camera to see your results.
To add an arch to a parapet wall
  1. Using the Select Objects tool, click on the 2nd floor parapet wall that will have an arch, then click the Open Object  edit button.
  2. On the Structure panel of the Wall Specification dialog that displays, select the Balloon Through Ceiling Above option under the Ceiling Platform heading, then click OK.
    In the Wall Specification on the Structure panel set your ceiling platform to balloon through ceiling above.
  3. Select Build> Roof> Roof Plane from the menu and perform the following:
    • Left-click and drag to create the roof plane's baseline spanning both the interior and exterior of the parapet wall.
      Note: A Question dialog may appear stating that "This operation creates or modifies a roof plane. With Auto Rebuild Roofs turned on, your changes will be lost the next time the roof is rebuilt. Would like to turn Auto Rebuild Roofs off and continue with the operation?" Choose Yes to proceed.
      Drawing the roof plane's baseline in a floor plan view
    • Once the baseline has been created, move the mouse to the opposite side of the structure and click where you would like the roof plane to stop at.
      Moving the mouse to the opposite side of the building to create the roof plane
    • Adjust the left and right edges of the roof plane, as needed. The left edge of the roof plane will be where the arch starts, while the right edge will be where the arch stops.
      In this example, we created a roof plane that is 24' in length and centered on the structure.
      Adjust the left and right edges of the roof plane to establish the arch
  4. Select the roof plane and click the Open Object  edit button.
  5. On the General panel of the Roof Plane Specification dialog:
    In the roof plane specification set your pitch to 0 and check the curved roof option.
    • Specify a value of 0" in the Pitch input field.
    • Check the box beside Curved Roof.
    • Set the Angle at Eave value to 30°.
    • On the Structure panel, uncheck the Use Room Ceiling Finish box located under the Roof Layers heading.
  6. Create a Camera  view to see the results so far.
    Take a 3D overview to see your results.
  7. Next, while remaining in the camera view, open the Layer Display Options dialog by navigating to Tools> Layer Settings> Display Options , or access the Active Layer Display Options  side window.
    While in a camera view use the Layer Display Options to turn off the Roof Planes and Roofs, Gutters layers.
    • Scroll down the list of layers to find the "Roof" layers or use the Name Filter to filter by keyword.
    • Turn off the display of the "Roof Planes" and the "Roofs, Gutters" layers.
    • Click OK.
    See your results in your 3D camera overview.
  8. If wall caps are desired, select the 2nd floor walls using the Select Objects tool, click the Open Object edit tool, and on the Wall Cap panel of the Wall Specification dialog that appears:
    If desired you can specify a wall cap on the Wall Cap panel of the wall specification.
    • If necessary, uncheck the No Change box.
    • Click the Add New button to browse the library for a suitable profile, then click OK.
      A variety of wall cap profiles can be located by navigating to Chief Architect Core Catalogs> Architectural> Moldings, Profiles, Extrusions> Handrails and Caps, and Sills and Caps.
    • Make any desired adjustments to the Width and Height, then click OK
To build framing*
  1. In a floor plan view, select Build> Framing> Build Framing  from the menu.
  2. In the Build Framing dialog that displays, check the Floors, Ceilings, and Walls boxes under the Automatically Rebuild Framing or Build Framing Once section, then click OK
    In X15 and prior, access each of the various dialog panels, check the appropriate Build Floor/Ceiling Framing and Build Wall Framing boxes, then click OK.
    Note: You may be presented with several Question dialog boxes asking if you'd like to display framing layers in the current view. For the purposes of this example, we will select Yes to turn on the layers related to our wall framing. However, in your case, you may want to switch to one of your "Framing" plan views prior to this step, if you don't want to display framing in your currently active plan view.
  3. Navigate to 3D> Create perspective View> Perspective Framing Overview  to see a camera view of the framing.
    Take a 3D framing overview to see your results.
