I need to create a custom object, what tool should I use?
![Create custom objects using polyline solids in Chief Architect Real time ray trace perspective view of a mirror created with a 3D/Polyline Solid hanging on a living room wall](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-prettypic-14.png?1680129392)
A 3D Solid, also known as a Polyline Solid in X13 and prior versions, is a generic, 3D shape that has a specified thickness. They can be oriented either horizontally or vertically and are useful for creating custom details anywhere in your 3D model.
A horizontal 3D Solid can be created in floor plan view, or any 3D view, by selecting the 3D Solid tool and then clicking and dragging to draw a rectangle. In X13 and prior versions, you can select the Polyline Solid tool instead. A vertical 3D/Polyline Solid can be created in a cross section/elevation view in the same manner as in floor plan view. The 3D/Polyline Solid is placed in front of any objects visible in the view. If no objects are behind, the 3D/Polyline solid is placed one foot in front of the camera.
3D/Polyline Solids can be edited the same way as other closed polyline-based objects.
In this article, a custom shaped mirror will be created.
To create and edit the shape of a 3D/Polyline solid
- From the menu, select 3D> Create Orthographic View> Cross Section/Elevation
and create an elevation view.
In this example we are working in a new, blank plan.
- From this new elevation view, select Build> Primitive> 3D Solid
, then click and drag to create a rectangular 3D Solid.
In X13 and prior versions, navigate to Build> Primitive> Polyline Solid
instead.
![A rectangular polyline solid.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure01-10.png?1680129392)
- Click on one side of the rectangle to activate that side. Notice that the edit handle on that side is now larger than the other sides. The active side is the side that will move when modifying dimensions.
The active edit handle can be a different color than the rest. By default, the handle will be red, but it can be changed on the Colors panel that's located in the Preferences dialog.
![Selected edge is red.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure02-10.png?1680129392)
- Use temporary or manual dimensions to resize the rectangle to a basic 24" by 24" square.
![Resizing using the temporary dimensions.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure03-10.png?1680129392)
- Next, click CAD> Lines> Draw Line
, then click and drag to draw four lines across the square 6" from the sides as shown:
![4 reference lines for the polyline solid.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure04-10.png?1680129392)
- With the Select Objects
tool active, select the 3D/Polyline Solid.
![Polyline solid is selected](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure05-10.png?1680129392)
- On the Edit toolbar, click the Add Break
tool and use the Intersections
snap indicator to help place breaks points precisely where the lines intersect the 3D/Polyline Solid.
![Placing a line break.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure06-10.png?1680129392)
- Continue making break points at all intersections.Select the Sticky Mode
secondary edit tool if you'd like to place multiple break points without having to re-select the Add Break
tool each time.
![All break points placed.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure07-10.png?1680129392)
tool, select the top edge of the 3D/Polyline Solid and click the Change Line/Arc
edit button, then use the small triangular edit handle on the edge of the arc to increase the arc's height until it is 6" tall.
![Convert edges to arcs.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure08-10.png?1680129392)
- Continue using the Change Line/Arc edit button to convert the middle sections of each side to arcs of 6" in height.
![Increase arcs to 6 inches in height.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure09-10.png?1680129392)
To create a hole in the 3D/Polyline solid
- Select CAD> Circles> Circle
from the menu, and using the CAD line intersections within the 3D/Polyline Solid, click and drag to draw a circle.
![Drawing a circle.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-figure10-10.gif?1680129392)
- Select the CAD circle and then click the Convert Polyline
- In the Convert Polyline dialog, select 3D Solid Hole option and click OK.
In X13 and prior versions, select Polyline Solid instead, then click OK.
- In X13 and prior versions, on the General panel of the Polyline Solid Specification dialog, check the Hole in Polyline Solid box, then click OK.
![Check the Hole in Polyline Solid box on the General panel](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-fig11-13.png?1680129392)
A hole can also be created by first selecting the 3D/Polyline Solid, selecting the 3D Solid Feature/Create Hole edit tool, then clicking and dragging inside the solid.
To edit the thickness and material
tool, select the main 3D/Polyline Solid, then click the Open Object
- In the 3D/Polyline Solid Specification dialog that opens:
![In the 3D Solid Specification set your depth to 1/2"](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-fig12-15.png?1680129392)
- In X14 and newer versions, on the 3D Solid panel, set the Depth to 1/2".
In X13 and prior versions, on the General panel, set the Thickness to 1/2".
- On the Materials panel, select the 3D/Polyline Solid sub-component, click the Select Material button, then search for a Mirror material.
![In the Select Material dialog find your desired material and click OK.](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-fig13-15.png?1680129392)
- Once the desired material is chosen, click OK and OK a second time to confirm the changes and close both dialogs.
To add the 3D Solid to your User Catalog
tool, select your 3D Solid and click on the Add to Library
edit button to add the object to the User Catalog.
In X14 prior versions, the 3D/Polyline solid must be part of an architectural block before it can be added to the User Catalog. Please see the "Adding a 3D/Polyline Solid to the User Catalog" resource in the Related Articles section for more information.
- To use this 3D Solid in the future or in a different plan file, select it from your User Catalog and place it into your plan.
Additional examples created using 3D/Polyline Solids
- Bookends
![Bookends created using polyline solids](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-bookends-7.jpg?1680129392)
- Gingerbread fachwerk architecture
![Gingerbread fachwerk](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-bavarian_fachwerk.gif?1680129392)
- An arched soldier course
![](https://d2haqc5836ials.cloudfront.net/live/KB-02925/2925-arched_soldier.jpg?1680129392)
