I would like to share a 3D Viewer model file of my drawing with a client that is using the Chief Architect 3D Viewer mobile app.
What settings or changes should I keep in mind before exporting the model?
Starting with the Chief Architect X8 18.3 update, you can export 3D Viewer model files to share with clients using the free Chief Architect 3D Viewer mobile app.
To ensure that your model can be opened on a variety of devices, it's a good idea to optimize your design before exporting. There are two ways to do this: by limiting the model's Surface Count, and by controlling its Texture Size, or the amount of memory required to load the model's material textures. You can find these metrics in the Export 3D Viewer File dialog when you export a model. It's recommended to keep the Surface Count below 500,000 and the Texture Size below 50 MB.
The easiest way to optimize a model for use in the Chief Architect 3D Viewer is to limit its Surface Count. You can do this by reducing the number of objects included in the model prior to exporting, by creating one or more custom layer sets in which unneeded layers are turned off.
Consider setting up several layer sets with varying complexity, in case your client's mobile device is unable to view more detailed models. Please see the "Understanding Layer Sets" resource in the Related Articles section below for more information.
Another way to optimize a 3D model for export is to control its Texture Size. Materials often use texture images to create a sense of realism, but if your plan uses custom materials with high-resolution image files as textures, some mobile devices will have trouble loading them. To avoid this, create copies of these files at a lower resolution using photo editing software and replace them before the export.
If you make extensive use of custom materials with high-resolution textures, consider using File> Save As to create a copy of your plan specifically for exporting to the 3D Viewer so that your main working plan is not affected by these changes.
512 x 512 pixels is a good size for square texture images.
