I see an AR mode in the 3D Viewer. What is the purpose of this mode?
AR, or Augmented Reality, can be used to help visualize what a digital file or model will look like in a real world environment. In terms of the 3D Viewer, you can place your 3D model onto a real world surface such as a table, and navigate around it. Follow the steps below to learn more about using this mode.
AR is supported on specific Apple iOS, iPadOS, and Google Android devices. To check to see if your current device is supported, please access the appropriate link below:
If you're experiencing trouble detecting an eligible surface, please see the Tips for Detecting AR Surfaces section below.
If you're having trouble detecting an eligible surface, consider these tips:
If you continue to experience problems with detecting eligible surfaces, and your device meets the requirements for AR, feel free to print a marker image and place it on the surface that you would like to use. Hover the device over the printed marker so it has an unobstructed view and fills at least 25% of your device's screen. When the device detects the image, it will place the model on top of the marker.
