I would like to add hyperlinks to text in my projects. Is this possible?
Adding hyperlinks to text can easily be done in Chief Architect, though the process may differ depending on the tool and version you're using.
In X15 and newer versions, hyperlinks that link to web pages, both in the views they are created in as well as when printed to PDF, can be added to rich text objects.
Hyperlinks can also be added to simple text objects that can be used in the views they are created in, but not when printed. These hyperlinks can link to both web pages as well as files on the local system.
To add hyperlinks to rich text objects*
*Applies to Chief Architect X15 and newer versions.
- Navigate to CAD> Text> Rich Text
, then left click and drag to create a rich text object in your desired location.
- Type in your desired text, as shown in the image below.
If you have already created a rich text object that you would like to add a hyperlink to, simply select it, then click the Open Object or Edit Rich Text in Place edit tool to display the Rich Text Specification.
- Highlight the text that you would like to add a hyperlink to, then click the Insert Hyperlink
option.
- In the Insert Hyperlink dialog that opens next:
- The highlighted text will display in the Text field.
- Use the Address field to specify a desired website address, or URL, of the page that the link will access.
If this field remains empty, the hyperlink will be removed from the highlighted text.
You can also remove a hyperlink from linked text by right-clicking and selecting Remove Hyperlink from the contextual menu while the text is in an editable state.
- Click OK.
- Click outside of the rich text box and notice that the hyperlink text is automatically underlined and assigned a non-default blue color, as shown below. Once created, though, it is editable.
- Now, if you select the rich text object and hover over the linked text, the mouse pointer will display a pointing hand
icon, the Status Bar will report the address that it links to, and you can click once to open the link in your default web browser.
To add hyperlinks to simple text objects
- Navigate to CAD> Text> Text
, then left click once to create a text object in your desired location.
- In the Text Object specification dialog that displays:
- On the Text panel, type in your desired text.
- On the Link panel, specify a desired website address, or URL, in the Hyperlink field or click the Browse button to link to a selected file on the local system.
Click the Test Link button to confirm that the address or pathname in the text field is associated with a web page or available file.
Chief Architect automatically adds the http:// prefix for links that begin with "www" when Test Link is clicked.
- Click OK.
- Now, select the simple text object, then click the Follow Hyperlink
edit button to activate the link.
