I have adjusted some rendering properties as well as the position of one of my saved camera views, and would now like to reset the camera view to its last saved state. Is there an easy way to do this with the camera view still active?
The Reset Saved Camera tools can be used in Chief Architect X16, Home Designer 2025, and newer program versions to quickly reset the properties and/or position of an active saved camera view.
To reset the properties and position of a saved camera view
- Resetting a camera view's properties and/or position requires an active saved camera view.
Camera views can be saved in Chief Architect by navigating to Tools> Active View> Save Active View
or by clicking on the Save Active View
tool while a camera view is active.
In Home Designer, navigate to 3D> Save Active Camera
or click on the Save Active Camera
- While in a saved camera view, navigate to 3D> Camera View Options
and notice the two Reset Saved Camera tools:
Reset Saved Camera (All)
- will reset all properties associated with the camera view back to the last saved state, including the rendering properties, lighting, positioning, as well as any other view specific settings that have been changed since the view was last saved. This includes all properties within the view's Specification dialog.
Reset Saved Camera (Position)
- will reset the camera's positioning properties back to the last saved state. This includes the options located on the Positioning panel of the view's Specification dialog.
