Can I limit what I see with a cross section or elevation camera?
In Chief Architect, cross section/elevation camera views can be clipped in various directions, allowing you to cut or remove the display of objects from the view, including entire floors. This is a great way to isolate a single room, a single floor level, or a specific area in the plan.
The ability to step a cutting plane is also helpful if you want to cut objects from the view, even if they're located on the same floor level.
To clip a cross section/elevation view using the specification dialog
- Navigate to 3D> Create Orthographic View
, then select the Cross Section/Elevation
, Backclipped Cross Section
, or Wall Elevation
tool.
Automatic elevation views can also be created. To create exterior elevations that will display content from all floors, navigate to 3D> Create Auto Elevations, then choose an appropriate option. To create interior elevations that will display content from a specific room on a specific floor level, select a room, then click on the Create Room Elevation Views edit tool.
- With the tool selected, click and drag towards a wall to create a section/elevation view.
In this example, the Cross Section/Elevation tool was used to create an exterior elevation, as shown in the image below.
![Creating a cross section view](https://d2haqc5836ials.cloudfront.net/live/KB-00066/66-fig1-13.png?1718911850)
- In the section/elevation view that generates, navigate to Tools> Active View> Edit Active View
In Home Designer Pro, navigate to 3D> Edit Active Camera
instead.
![Elevation view of a structure displaying content from all floors](https://d2haqc5836ials.cloudfront.net/live/KB-00066/66-fig2-13.png?1718911850)
- On the Camera panel of the Specification dialog that displays, focus on the settings located under the Scene Clipping section.
![Camera panel of the Cross Section/Elevation Specification dialog where the view can be clipped.](https://d2haqc5836ials.cloudfront.net/live/KB-00066/66-ElevationSpec-16.png?1718911850)
- Check Display Poché* to apply a dark fill to the clipped edges of walls, floor and ceiling platforms, and roof planes in the view.
*Applies to Chief Architect X16 and newer versions.
- Check Framing Back Clip* to include only the framing objects or portions of framing objects located between the start and end points of the camera's Line of Sight in the view. When checked, you can specify the Back Clip Framing After distance, which is the distance from the camera's position beyond which framing objects are clipped.
*Applies to Chief Architect X15, Home Designer 2024, and newer versions.
- Check Back Clip to include only the objects or portions of objects located between the start and end points of the camera's Line of Sight in the view. When checked, you can specify the Back Clip After distance, which is the distance from the camera's position beyond which objects other than framing are clipped. It is also the length of the camera's Line of Sight from the cross section line at its start to the back clip line at its end. This text field reports the length of the camera's Line of Sight even when the setting is unchecked.
This box is checked by default for backclipped cross section views.
In this example, we have checked the Back Clip box and specified a Back Clip After value of 400".
- Check Clip Sides to limit the selected view’s side-to-side extents. When checked, you can specify a Clip Width value and/or use the newly displayed edit handles at each end of the cross section line to adjust the view. When unchecked, the full width of the model is included in the view.
![Using the edit handle to adjust the side clipping of an elevation](https://d2haqc5836ials.cloudfront.net/live/KB-00066/66-gif1-13.gif?1718911850)
- Check the Clip Elevation box, then specify values for the Bottom Clip Elevation and Top Clip Elevation fields. When unchecked, the full height of the model is included in the view.
The display of the foundation floor level can also be controlled using layers. To learn more, please see the "Turning Off the Display of the Foundation in a Cross Section/Elevation View" resource located in the Related Articles section.
- A Clip to Room setting is also available. When checked, the extents of the current view will be confined to the room that the camera is located in and framing objects will not be visible. The view's clip values are reported above for reference, but will be grayed out. This box is checked by default for Wall Elevation views and is only available if the camera is located inside of a room.
When this setting is checked or a Wall Elevation camera is being edited, some additional options are available:
Ignore Railings and Invisible Walls will ignore the room definition created by these types of walls. When this is unchecked, only room definition created by regular walls is recognized.
Ignore Walls Above will prevent any walls located above the selected camera's room from displaying in the view. This option typically has an effect only when the camera's room has Flat Ceiling Over This Room unchecked, or the room above has Floor Under This Room unchecked, in the Room Specification dialog.
Once all desired changes have been made, click
OK.
Specifying a backclip line with an appropriate distance value allowed us to isolate the garage, as shown in the image below. If we wanted to remove the foundation from the view, we could have also checked the Clip Elevation box and raised the value of the Bottom Clip Elevation.
If you don't want to see clipping plane lines in a section or elevation view, access the Layer Display Options or Active Layer Display Options side window, locate the "CAD, Clip Lines" layer, then remove the check from either the Disp column or the Display checkbox.
![Section view displaying only the garage](https://d2haqc5836ials.cloudfront.net/live/KB-00066/66-fig4-13.png?1718911850)
To clip a cross section/elevation view using clipping plane lines*
*Applies to Chief Architect X13, Home Designer Pro 2022, and newer versions.
- In a cross section/elevation view, navigate to Tools> Active View> Edit Active View
instead.
- On the Camera panel of the Specification dialog that displays, check the Clip Sides and/or Clip Elevation box, then click OK.
- In the cross section/elevation, clipping plane lines will be appear on the sides if Clip Sides was checked in the step above, or on the top and bottom if Clip Elevation was checked.
![Elevation showing the clip lines](https://d2haqc5836ials.cloudfront.net/live/KB-00066/66-fig8-14.png?1718911850)
tool, select a clip line and use the various edit handles that display to adjust its position.
![Elevation with the clip lines selected and being modified with the edit handles](https://d2haqc5836ials.cloudfront.net/live/KB-00066/66-fig9-14.png?1718911850)
- If you don't want one of the clip lines to be a straight line/edge, you can use the various edit buttons that display on the Edit toolbar to modify the shape:
- Use the Add Break
tool to add a break point on a clip line.
- Use the Change Line/Arc
edit button to change a line to an arc.
- Repeat Steps 4 - 5 with the other clip lines until the view is clipped, or cropped, to your liking.
![Elevation view after editing the clip lines](https://d2haqc5836ials.cloudfront.net/live/KB-00066/66-fig10-14.png?1718911850)
