How can I offset my railings, rails, or newel posts from the floor platform they are associated with?
The entirety of a railing, which consists of balusters, newel posts, and rails, can be offset using the Horizontal Offset setting located on the Rail Style panel of the Railing and Deck Railing Specification.
Individual rails, newel posts, and start and end posts, can also be offset independently by accessing their respective panels within the Railing and Deck Railing Specification.
To offset an entire railing
tool, click on the railing or staircase that you want to offset, then click the Open Object
- On the Rail Style or Railing panel of the dialog that displays, specify either a positive or negative value in the Horizontal Offset field, then click OK.
To offset individual rails
tool, click on the railing or staircase that you want to offset the individual rails for, then click the Open Object
- On the Rails panel of the dialog that displays, notice that Horizontal and Vertical Offset columns are available for each rail within the Rail Profiles table.
- Double-click in the desired cell to change to open the field for editing, enter in your desired value, then click OK.
To offset newel posts
tool, click on the railing or staircase that you want to offset the newel posts for, then click the Open Object
- On the Newels/Balusters panel of the dialog that displays, under the Newels/Posts section, specify either a positive or negative value in the Horizontal and/or Bottom Offset fields, then click OK.
Individual newel posts can also be adjusted manually using the Move Newels edit tool. To learn more, please see the Related Articles section below.
