Transferring a Camera's Properties to Other Camera Views
Reference Number: KB-03196
Last Modified: March 21, 2025
How can I easily transfer properties that I have specified in one of my camera views over to another camera view?
If several modifications have been made to a particular camera view, and you now want to copy, or replicate, them across other camera views, consider copying/pasting the view or setting the particular view as the default for the camera tool.
To copy and paste cameras
  1. With a camera or cross section callout selected in a plan view, navigate to Edit> Copy , select the Copy/Paste  edit tool, or press the hotkey command Ctrl/Command + C to copy the view.
    Note: Camera views can also be duplicated using the Project Browser, though this will simply create a copy on top of the original.*
    *Applies to Chief Architect Premier and Chief Architect Interiors only.
  2. Navigate to Edit> Paste> Paste or press the hotkey command Ctrl/Command + V, then click where you want the copied camera to be placed.
To set a camera as the default for a camera tool*
  1. In a plan view, select the camera or cross section callout that you would like to set as the default.
  2. Click on the Set As Default  edit tool. A Question dialog will display stating: "The [CAMERA TOOL] Defaults will be updated. Do you want to continue?" Click Yes to proceed.
    Question dialog asking if the defaults should be updated
MORE INFORMATION
  • Cameras can be copied between plan files. After copying a camera, navigate to the desired plan, then use one of the various Paste tools or hotkey commands.
  • Additional edit tools can be used in unison with the camera copying process. To learn more, please see the "Copying and Pasting Objects" section located within your program's documentation.
  • It's important to note that cross section/elevation views cannot be rotated after they have been created/placed.
