I have a cabinet or other item on the first floor, and I want it in the exact same place on the second floor. How can I do this?
You can easily copy and paste objects between floors using the Paste Hold Position tool.
To copy objects between floors
- With at least two floors present in a plan, and the item you wish to copy already placed, select the object and click on the Copy/Paste
Alternatively, you can navigate to Edit> Copy
- Click on the Up One Floor
or Down One Floor
button to navigate to a different floor.
Alternatively, you can navigate to Tools> Floor/Reference Display> Up One Floor
or Down One Floor
- Navigate to Edit> Paste> Paste Hold Position
and the object will paste in place, keeping the same X and Y coordinates of the copied object.
