Creating an L-Shaped Cabinet Without a Center Stile
Reference Number: KB-03203
Last Modified: April 17, 2025
How can I create an L-shaped cabinet or bookshelf without a center stile or separation?
Kitchen with an L-shaped corner cabinet
An L-shaped cabinet or bookshelf without a center/corner stile or separation can be created using two separate cabinets and modifying their properties to simulate a single, seamless cabinet. However, accomplishing such a task requires you to disable the Automatic Blind Corner Cabinet functionality within the General Cabinet Defaults.
Note: To create an L-shaped corner cabinet with double doors or to create a blind corner cabinet, please see the "Creating a Corner Cabinet" resource in the Related Articles section below.
To create an L-shaped cabinet without a center stile
  1. In your plan, navigate to Edit> Default Settings, expand the Cabinets category, select the General Cabinet option, then click Edit.
    Default Settings dialog with General Cabinet selected
  2. In the General Cabinet Defaults dialog, remove the check from the Create Automatic Blind Corner Cabinets box, then click OK and Done.
    General Cabinet Defaults dialog with the Create Automatic Blind Corner Cabinets box unchecked
  3. Navigate to Build> Cabinet  and choose your desired Cabinet  tool.
    In this example, the Wall Cabinet tool is selected.
  4. With the tool selected, click in the plan to place two cabinets, side-by-side.
    Two wall cabinets placed side-by-side in floor plan
  5. Rotate one of the cabinets that was placed, then adjust the size of each cabinet until they form an L-shape.
    Cabinets rotated and resized to create an L-shaped cabinet
  6. Using the Select Objects  tool, click on the smaller of the two cabinets, click on the Open Object  edit tool, and in the Cabinet Specification dialog that displays:
    Front/Sides/Back panel of the Cabinet Specification dialog where the Side and Side Type can be modified
    • On the Box Construction panel, select the Framed option under the Box Construction section, then set the Separation value to 0.
    • On the Front/Sides/Back panel, ensure that the Side drop-down is set to Front, then adjust the face items, as necessary.
      In this example, we deleted the Door face item.
    • Remaining on the Front/Sides/Back panel, use the Side drop-down at the top and set it to Left or Right; use the Side Type drop-down to set it to None, effectively removing the side panel from the cabinet.
    • Make any other desired changes, then click OK.
  7. Next, select the larger of the two cabinets, click on the Open Object  edit tool, and in the Cabinet Specification dialog that displays:
    Box Construction panel of the Cabinet Specification dialog
      In this example, we deleted the Drawer and Door face items.
    • Click OK.
  8. Take a Camera  view to see the results.
    Camera view of an l-shaped wall cabinet
  9. Consider blocking the two cabinets together using the Make Architectural Block  edit tool. You can then add the block to the User Catalog area of the Library Browser by clicking on the Add to Library  edit tool for use in other projects.
